Slow CAT control
K0HB
Slow CAT control
Post by K0HB »
I have a longstanding issue with slow CAT control.
When I click on a spot in the cluster window the rig QSY is very delayed, a matter of several seconds in most cases. If their is a change of mode involved, sometimes the mode is first changed, followed by another delay to QSY the frequency.
I am using OMNIRIG for radio control, rig is FTdx5000. This delay does not happen in others applications.
DE Hans, KØHB
"Just a boy and his radio"
Superstition Trails ----> http://OldSlowHans.com
Re: Slow CAT control
please enable trace mode in help menu, work with CAT to reproduce the issue then send me (lele (at) pisto.it) a "support request" package (last item in the help menu) that contains all relevant logfiles.
K0HB
Post by K0HB »
What will be the name/folder of log files?
DE Hans, KØHB
K0HB
Post by K0HB »
OK, I have sent you a support request package.
DE Hans, KØHB
K0HB
Post by K0HB »
Thank you for chasing down this problem.
QSY's are now crisply executed!
DE Hans, KØHB
hb9cat
Post by hb9cat »
I have the same problem, how was it solved ?
Marco HB9CAT
W1CAB
Post by W1CAB »
Yes, same issue here with slow CAT control. Sometimes I don't think it is going to change at all and close the program.
Using Yaeus FT-450.
Check the polling interval in Omnirig, it should be set to about 100
Nelob wrote:Yes, same issue here with slow CAT control. Sometimes I don't think it is going to change at all and close the program.
Using Yaeus FT-450.
What is your call sign?
W1CAB
Post by W1CAB »
Sorry about that it's W1CAB
Changing the polling did the trick by the way. Just about instant now.
Thanks,
Craig W1CAB
