Minor typos
Posted: 26 May 2015, 18:42
by PB4FUN
Under Cluster (F9) there appears on the right side a tabcontrol
The caption is Highligts -> should be Highlights
Under that the caption of the Radiogroup control is "Highlight spot by" where all options are starting with "by" (being the first option starting uppercase). -> either remove the word "by" in the caption or in the caption of each radiobutton
You also use the casing of kHz different on multiple places. The official casing should be lower k, upper H, lower z (Using MHz the M is uppercase)
Re: Minor typos
Posted: 28 May 2015, 04:42
Thanks,
all fixed :)
Re: Minor typos
Posted: 05 Jul 2015, 17:41
by VE3VEE
Help > LogOm Homepage (should be "Log4OM Homepage") :-)
Re: Minor typos
Posted: 08 Jul 2015, 08:24
Oooops!
