i am OE3OSB - and finaly i found MY Logging Program - tks for that ! Until now, i logged all my QSOs in QRZ.COM and then i synced it with LOTW and all others.
I faced 2 points where i need your help pls.
1. If i use the Audio Keyer - it is only possible to send the voice message out if i activate on my 7410 the "D" Digital Mode.
If i dont activate the D - then only TX goes active and nothing happens ...
2. Since i use Log4OM i got LOTW confirmations to QRZ.COM w/o date (00.00.0000) - any Idea why this happens ?
Mni tks for your response
Erich (OE3OSB)
ICOM IC-7410
Re: ICOM IC-7410
Yes I beleive the only way to do it without being in Dat mode on the 7410 would be to port the computer audio into the rigs mic socket, unless there is a menu setting on the rig that you can changeOE3OSB wrote:1. If i use the Audio Keyer - it is only possible to send the voice message out if i activate on my 7410 the "D" Digital Mode.
That is very strange, could you download an ADIF of your confirmations from the LOTW website and email it to me for evaluation please2. Since i use Log4OM i got LOTW confirmations to QRZ.COM w/o date (00.00.0000) - any Idea why this happens ?
