struggling to get Dropbox to sync the database
Posted: 29 Jun 2015, 08:55
I’m still struggling to set this up to work, so I can sync my Log4OM database between PCs.
I think it is a problem on the dropbox side more than anything to do with Log4OM.
I already have dropbox on my main home PC, which syncs with files uploaded to my dropbox from my Android phone using the dropbox app and another app called dropsync (which fills what I consider a stupid lack of functionality in the dropbox app).
My PC then pulls down and syncs with whatever is upload to my dropbox cloud by the phone.
I’ve seen Terry say to ensure you use the ‘proper’ PC dropbox, so I thought I’d start over with a clean install on another PC in case the one on my home PC was not.
I went here
https://www.dropbox.com/
and clicked the “Download the app” link, which was an installer, and then installed the app. It looks and operates the same as the home PC as I see. By default it offered all the folders up on my dropbox cloud.
As I doubt the user based documents path will be the same across all PCs I might want to sync across, I figured a Log4OM folder in root of C: was a pretty bombproof place to put it, so created a folder.
I already had made a Log4OM folder (empty) on the cloud via browser.
I was able to right click the PC folder ( C:\Log4om ) and “send to” Dropbox.
I created a test.txt file on my HD to simulate having something to sync UP to the cloud. (Which I how I assume it can only work.)
Nothing happens. It appears that my PC based dropbox is only set to receive, and never transmits?
Have I the wrong thing installed?
I cannot see any setting that seems to instigate an upload from the PC.
I went here
