Grid Square distance calculations
OZ8PG
Post by OZ8PG »
Dear Log4OM team.
Tank's for latest update with many good new features ;)
I need distance calculation from my location to other stations using the gridsquares fx on 50MHz and up!
The distance calc seems to be correct if you enter the correct locator at first log-entry.
But trying to correct it later, fails every time.
If the first locator is found to be wrong, and you correct it with "update QSO" window - leave it using "update" - "save and exit"
still no recalc happens.
Best regards and still happy to use Log4OM
OZ8PG / Per
Re: Grid Square distance calculations
I will check that, thanks for reporting
Lele
