Error message upon lookup
Posted: 12 Jul 2015, 18:12
by AC7CW
If I use QRZ for lookups it's fine. If I use HamQTH via the internal browser I get an error message "An error has occurred in the script on this page" and "Object doesn't support property or method "Initialize". If I open up IE and lookup the same call on HamQTH I don't get any error message.
Computer has a fresh install of Win 7, I run Log4OM in a User account without Admin privileges, that might be giving me errors that others don't see. I do however run it with admin privileges as per the instructions. I have tried XP compatibility mode and still get the annoying error message.
Re: Error message upon lookup
Posted: 12 Jul 2015, 18:51
You don't need to use XP comparable mode but you should run the program with administrator priveledges.
Clearly there is something on the Hhamqth page that we don't like so I think only Lele can advise, I will ask him to check this out
Posted: 12 Jul 2015, 20:49
It's the .net default browser that is still at the stone age...
I must search for an alternative...
Posted: 15 Jul 2015, 14:40
by AC7CW
Thanks much
Posted: 10 Sep 2015, 20:37
by oh1haq
Hi!
I'm trying to help a friend to switch from hrd to log4om. The same problem is with hrd too (much worse actually, with javascript acting up.
Could the bug be worked aroud so that the lookup would open up your default browser? At least until the root cause is fixed.
Thanks!
Posted: 10 Sep 2015, 21:48
by VK7XX
IW3HMH wrote:It's the .net default browser that is still at the stone age...
maybe one of these will help
http://midori-browser.org/download/source/ or
http://www.netsurf-browser.org/downloads/source/ or
https://www.webkit.org/ or even
https://www.chromium.org/chromium-os
John
Posted: 14 Sep 2015, 16:29
It seems no one is embeddable into a form...
