SOTA new associations
Moderator: OE6CLD
I have added the two new SOTA associations that became active on Saturday, Singapore and Reunion Island
Please update your SOTA files by using the SOTA Database/Download in the Log4OM settings menu - This will update our SotaAssociations file and also the SOTA summitlist.csv
G0VWP
Re: SOTA new associations
Post by G0VWP »
I have been on SOTA this morning and got a new one but the one that i want to put in the log is new and is not there the association is Austria the area is Oberosterreich there 55 new sota's from 387 to 441 can you update them ?.
Terry
G0VWP
TERRYG0VWP wrote:Hi Terry,
Terry
G0VWP
Terry,
This is not a new association which I have to update, you are referring to new summits within an association.
My guess is that you have not set Log4OM to automatically update the SOTA summitbase file frequently enough if at all because as you will see from my screen shot the references are already there.
1. Options/Settings 2 make it update every 7 days
2. Settings drop down menu - Check enable auto update
Because you clearly have not updated you should also go to the settings drop down and click on 'SOTA Database' - Download updates
G0VWP
Post by G0VWP »
I have done the changes set to Enable Auto update and set Update SOTA File every 7 days.
But it still say's there is only 386 summits Oberosterreich area.
Should this update right away when done or will it wait the 7 days
73 Terry G0VWP
73 Terry G0VWP
You missed my last instruction
G0VWP
Post by G0VWP »
I have done all you have said but still no updates to any of the summits.
Terry
G0VWP
Did you restart Log4om after you did the manual SOTA update?
G0VWP
Post by G0VWP »
I did restart Log4OM and all is the same no updates to the summits.
Do you have TeamViewer installed so that I can check what's happening ?
I have it updating correctly on three PC's and a Windows Tablet with all the updated information available as in my earlier screen shot
G0VWP
Post by G0VWP »
I don't have TeamViewer, do i have to down load this off the internet and if so not to good
with computers as you can see but will give it a try.
I have also loaded Log4OM on my laptop and it is the same there no updates to the summits
so i must be doing something wrong.
Thanks for all your help Terry, I do want get this up and running properly as i do kike the program, i also want to connect the
FTDX-5000D rig to the program but not till have sorted the summits out as that is my main concern co's i'm a big chaser and activator
of SOTA.
73 Terry
G0VWP
