Ic 7600 cat control Hamlib/omnirig not woking
Posted: 11 Aug 2015, 14:27
by PD1EHA
Hello i have install Log40m it looks verry nice.
But i have one problem, i cannot connect with my icom 7600.(usb)
I have try Hamlib/omnirig it will not work.
When it is connect he disable in 10 sec automatic.
Cluster is working correct en also import ADIF is no problem.
Cat status is RED
Re: Ic 7600 cat control Hamlib/omnirig not woking
Posted: 11 Aug 2015, 14:34
Are you sure that you have selected the correct com port and baud rate in Omnirig?
What is your call sign?
Posted: 11 Aug 2015, 14:47
by PD1EHA
Yes, com1 and baud rate 9600 stop bits 1.
(Try Omni-Rig and connect by selecting ICOM model IC-725a)
I have try this but also not works for me.
I have try also com 14 but it will not working for me.
Posted: 11 Aug 2015, 15:29
what port and baud rate for HRD?
CALL SIGN PLEASE
Posted: 11 Aug 2015, 22:40
PD1EHA wrote:I do a compleet new reinstall now i let jou now.
NO i,m sorry it will not work.
I stop now till there is a solution to solve this problem.
In the Icom menu check the "USB Serial Function" is
NOT set to Decode,
it should be set to CI-V.
Posted: 12 Aug 2015, 05:43
by PD1EHA
I have check it and it is on CI-V
Posted: 12 Aug 2015, 19:10
by PD1EHA
Ok i have try it again and i have cat connection pfffffffffff unbelieveble but it works,
Posted: 12 Aug 2015, 20:30
That's good news, what did you do?
Posted: 13 Aug 2015, 05:50
by PD1EHA
It is my own stupid fault.
If jou see the picture in the blue line that is the connection (ic7600 USB) (using com 10), also in use with HRD.
and one above there jou see com 1.
I thought i most have com1 and that was wrong (ic7600 is running with USB) and in my case COM10 uneblieveble stupid.
