Help with PowerSDR interface
Posted: 30 Aug 2015, 16:17
by n1eu
I'm unable to connect with my ANAN-100D running PowerSDR. I'm running a virtual COM port pair with VSPE. I connect fine with N1MM Logger + and DDUtil but no luck so far with Log4OM and OmniRig. I've got OmniRig set to PowerSDR and correct port, baud, etc. Maybe I'm missing something to get it to connect?
Thanks & 73,
Barry N1EU
Re: Help with PowerSDR interface
Posted: 30 Aug 2015, 16:46
Try Kenwood rd 2000
Posted: 30 Aug 2015, 17:59
by n1eu
No luck. Is there anything I need to do other than configure Omni-Rig settings after clicking on the headset icon and selecting RIG 1 in the Rig selector? Do I need to turn something on or should it just start working once the port settings are configured?
Thanks & 73,
Barry N1EU
Posted: 30 Aug 2015, 20:18
It should just work once it's configured
Make certain that no other software is using the VSP, Just PowerSDR at one end and Omnirig at the other
Are you sure the PowerSDR settings are ok because it works fine for me
Posted: 30 Aug 2015, 21:15
by n1eu
CAT Status shows red and Freq is empty. Doesn't that mean CAT isn't working?
I connect easily on the same port using N1MM Logger+ so I know it's all set up correctly outside of Log4OM.
Barry N1EU
