LOTW T-QSL 2.1
LOTW T-QSL 2.1
The ARRL has announced that ver 2.1 of T-QSL is now available from the ARRL website. Anybody tested it yet to see if all is OK?
73 Peter G3ZSS
Re: LOTW T-QSL 2.1
It worked FB with me.
Art
Art
- VK7XX
- Old Man
Re: LOTW T-QSL 2.1
same as Art.... all OK here !G3ZSS wrote:The ARRL has announced that ver 2.1 of T-QSL is now available from the ARRL website. Anybody tested it yet to see if all is OK?
John
Re: LOTW T-QSL 2.1
I am using recently Log4OM and no problem when uploading qso's to LotW. But no way to download the qsl's from LotW. Even downloading an ADIF file from LotW, when importing the data to the Log4OM database, there is no update on the LotW Received Status. It seems that the process is accomplished with success, but no data imported.
I do appreciate your help.
Alfonso
EA4DKJ
Alfonso
EA4DKJ
Re: LOTW T-QSL 2.1
Are you saying that we don't provide a download facility for LOTW? or that our download facility is not working?EA4DKJ wrote:I am using recently Log4OM and no problem when uploading qso's to LotW. But no way to download the qsl's from LotW.
The import of an ADIF by using 'file/import ADIF' is not designed to update the LOTW status or the status of any other data for existing QSO's you need to use the QSL manager for thatEven downloading an ADIF file from LotW, when importing the data to the Log4OM database, there is no update on the LotW Received Status. It seems that the process is accomplished with success, but no data imported.
Its works fine for me and you should see something like the screen shot below, and all new confirmations downloaded update the original QSO's
Re: LOTW T-QSL 2.1
Many thanks for your reply.
Sorry if I did not explain myself properly; of course, it is a matter of that the facility is not working on my PC, and I can not guess at all what is happening, as I do not have any problem on uploading QSO's.
I am attaching the screen I get.
Thanks for your help.
Alfonso EA4DKJ
Alfonso EA4DKJ
- image.png (147.55 KiB) Viewed 7203 times
Re: LOTW T-QSL 2.1
You probably are using the wrong user name, password or station ID for the download - Getting the station ID wrong is the most common issue with LOTW
The download it entirely different from the upload which uses the TQSL program, all that is required for download is a correct user name and password - Both are case sensitive
Re: LOTW T-QSL 2.1
Great, Terry.
You were right; I was using the wrong password. I was convinced I was using the right one as the uploading worked. How much time wasted wondering what was the the problem...
Many thanks!
Alfonso EA4DKJ
Many thanks!
Alfonso EA4DKJ
Re: LOTW T-QSL 2.1
No problem Alfonso, you are not the first to make that mistake and you wont be the lastEA4DKJ wrote:Great, Terry.
Many thanks!
Alfonso EA4DKJ
