LOTW again
Posted: 07 Jun 2013, 21:14
Laugh with me
Few day ago I found some news on some sites.
VK3AMA create a “JT-Alert for WSJT-X” (compliments)
What is WSJT ? As it Work ? See site of JoeTaylor, K1JT.
http://physics.princeton.edu/pulsar/K1JT/index.html
The Nobel prize is famous for many innovative ideas in radio protocols.
I want to hurt me and I download program. It is very simple to configure and use.
I select as cat “9999 Ham Radio Deluxe” and my homemade simulator program work well.
After some test of reception can a radio amateur don’t try a QSO?
My experiment is with a Spanish on 15 m bands. The QSO is correct and the ham is registered at LOTW.
Before going to sleep I try to upload the QSO to LOTW.
From some time I use the great Log4OM as log. Obviously (only for me ) I prefer do manually some operations. Search the line in ADIF file, put it in a temporary file, import in Log4OM.
Try to upload to LOTW. Error ?????? why ??????
Going to sleep is delayed…….
After a minute found that the mode field of QSO is blank. No problem. Add a line to ModeList.txt of Log4OM, delete the QSO and import again.
Well, now the record is imported and the line report JT9 in mode field .
Try to upload to LOTW with another negative result.
Try manually import file with TQSL program. The ADIF is not validated and tq8 file is not created.
What happens ?
The current version of TQSL is not valid ?
Some search in internet and I found a solution.
DANGER
Backup all your certificates before continue . See on LOTW site for details.
Logon to LOTW
Now navigate to your Logbook Account and select “Your Certificates”.
Download them in a directory. Do not overwrite existing files.
Now disconnect from site and start TSQLcer. Select your certificate.
From file select “Load Certificate File”. Select TSQL (.tq6)
If you read the note it contain also the configuration data. These mean also the new countries and also new modes.
Select the “Config.tq6” previously downloaded.
Confirm and exit program.
Start TQSL and go to Help - About
Now the “Configuration data” is updated.
The release is classic v1.13.
VICTORY !!! NOW LOG4OM UPLOAD MY QSO !!!
Good night de Sandro, IW3RAB
What happens ?
DANGER
Logon to LOTW
