Problem with PST rotator
iz2odm
Post by iz2odm »
Hello ,
I just updated LOG4OM to last version (1.14.0.0) and PST rotator , already configured ,was not able to work , no more.
I didn't change any configurations by previous version of LOG4OM and also into PSTrotator.
UDP Ports are open correctly (12040) , in both program.....
Anybody can help me?
Thanks and 73
Roberto, IZ2ODM
Re: Problem with PST rotator
Ciao Roberto,
Have you got the program and communicator running with administrator privileges?
See page 18 of the user guide.
You need to have set administrator privileges for both LogOMUI.exe and Log4OmCommunicator.exe
iz2odm
Post by iz2odm »
Hello and thanks for your suggestions.
I have WINDOWS XP as system and ther is not any administrator privilege into tab like you suggested.
Any furher helps?
Thanks and 73
Roberto
Hi Roberto.
Uninstall the program and then right click on the install.exe select run as administrator, when the install is finished the program should install and then run as an administrator.
iz2odm
Post by iz2odm »
Sorry but system also ask me Passowrd in case of entering as Administrator.
I didn't set this password , newer.
Any suggestions?
Thanks and
iz2odm
Post by iz2odm »
Further info Terry,
By checking my system , It seems that I already registred and set like ADMINISTRATOR.
Matter is quite complicate.....
Hi Roberto'
When I get home tonight I will check this out and get back to you
iz2odm
Post by iz2odm »
THANKS A LOT TERRY !!!!
Roby
Ciao Roberto,
I think you may have found a bug, I have a problem also!
This morning I have sent a message to Daniele, as soon as I receive a response I will get back to you.
Appologies for the inconvenience.
Hi Roberto,
Yes it was a bug and Daniele has fixed it.
Please download the 1.14 release again, this has the update!
Uninstall Log4OM
Install the fresh download
All should now work OK, please let me know how you get on.
Appologies to you and anyone else that had this issue but even we get the occasional glitch! :D
