Fldigi not changes freq. due to Growl "error network 201"
DK6WK
Post by DK6WK »
I configured Log4OM and fldigi as described in the Youtube video:
Log4OM running with Omnirig using flex radio 6300: perfect
Log4OM Communicator: Service status: all green. Rig Status: okay
Fldigi: only XML-RPC initialized. Not RigCAT etc.
The export of logs from Fldigi to Log4OM: perfect.
But freq. in Fldigi doesn't follow Log4OM and reverse. Her is the activity log. Do you have any idea which "network problem" could cause the problem?
Vy 73
Ray (DK6WK
2015-11-18 13:04:45.6909 INFO: NotificationManagement: Starting GROWL Service...
2015-11-18 13:04:45.6919 INFO: NotificationManagement: GROWL Service started
2015-11-18 13:04:45.6929 INFO: FldigiManagement: Initializing FLDigi communications
2015-11-18 13:04:45.7199 DEBUG: FldigiManagement: FLDigi URL http://localhost:7362
2015-11-18 13:04:45.7204 INFO: #=qje$IehhV$W0BRu75i71jzRmw54m0HOJiWfXS_mtIrtM=: Starting FlDIGI filesystem monitor
2015-11-18 13:04:45.7214 INFO: #=qje$IehhV$W0BRu75i71jzRmw54m0HOJiWfXS_mtIrtM=: Start FLDigi poller...
2015-11-18 13:04:45.7219 INFO: #=qje$IehhV$W0BRu75i71jzRmw54m0HOJiWfXS_mtIrtM=: FLDigi poller started
2015-11-18 13:04:45.7229 INFO: #=qje$IehhV$W0BRu75i71jzRmw54m0HOJiWfXS_mtIrtM=: Starting flDigiWorkerThread poller process with polling rate 1000
2015-11-18 13:04:45.7259 INFO: #=qje$IehhV$W0BRu75i71jzRmw54m0HOJiWfXS_mtIrtM=: ****** SERVICE STARTED *****
2015-11-18 13:04:45.7269 INFO: TCPClientManager: Connection established to 127.0.0.1:8081
2015-11-18 13:04:46.6934 ERROR: *** NotificationManagement: GROWL Error - 201 : The destination server was not reachable
2015-11-18 13:04:46.6949 ERROR: *** NotificationManagement: GROWL Error - 201 : The request failed to be sent successfully due to a network problem.
2015-11-18 13:04:46.6964 ERROR: *** NotificationManagement: GROWL Error - 201 : The response failed to be read successfully due to a network problem.
Re: Fldigi not changes freq. due to Growl "error network 201"
The Growl error has nothing to do with your issue the errors are there because either you don't have Growl installed or growl has not been configured
Did you check the two boxes in the communicator as shown below?
DK6WK
Post by DK6WK »
tnx Terry: That was my mistake. I checked the settings once more and "send to FLDigi" was not enabled :oops:
Ray (DK6WK)
