Is there a way to set the default to send a spot on all DX worked. When I log the DX contact it automatically sends a spot?
Dave N4XYZ
Spot all DX
Re: Spot all DX
No Dave there is not.
As a suggested new feature I would personally want to see a lot more users request this before even considering it.
How would you define DX? The QRP man sees it differently to the fellow with a five element beam for instance.
My vote will be nay for something that can be done manually already
Re: Spot all DX
Terry, I define DX as any country but my own. But I would not want to make it automatic but have it selectable. If you are in a DX contest and are operating assisted you probably would want to spot all that you worked. Other times you would want it turned off.
No big deal, I was really asking if that selectability already existed and I couldn't find it.
Thanks Terry for all your help.
Dave, N4XYZ
Dave, N4XYZ
Re: Spot all DX
Spot is a single click, just press the small button right to the callsign and log4om will create a spot for you with relevant informations (if any).
Automating spot will easily drive us to be reported as cluster spammers
