Tuner Reminder Dock
Posted: 10 Jan 2016, 15:30
by KI0EO
My suggestion would be the ability to "dock" tuner reminder to the main UI.
This would put it out front and visible at all times.
I just recently started using tuner reminder and find that it is an excellent tool for my operating needs.
Just a little set up on the users end and it works great.
Thanks for your hard work!
Don...KI0EO...
Re: Tuner Reminder Dock
Posted: 10 Jan 2016, 23:47
But its already on the top tool bar why do you need it twice?
Posted: 11 Jan 2016, 00:38
by KI0EO
I see it now.
My window border is typically set to transparent (Win 7).
With that, all black text blends into my desktop background.
Don...KI0EO...
Posted: 12 Jan 2016, 13:18
Any suggestion about placement, in Log4OM window at his minimum size?
I'm fully open to suggestions about that, except going in the third or fourth dimension
Posted: 14 Jan 2016, 15:41
by CT1BXX
IW3HMH wrote:Any suggestion about placement, in Log4OM window at his minimum size?
Daniele I think one thing would help: hide the value/label when it has no value (nothing)
Case - P:0 L:32 T:57 in this situation would be good to show only L:32 T:57
Posted: 15 Jan 2016, 12:47
by DF2MC
My recomendation regarding Tuner Reminder.
Placement: To have the choise, whether always on top of the main screen or not.
To move the window where ever it is convinient for the user on the main screen. (Size is OK)
In my case, I am using 3 different antennas, therefor are 3 different tuner reminder setting.
Allways on top means, I could check easily, do I have the right setting on my tuner, not going first to > Utilities > Tuner reminder
to recall this window, or bring it up from the taskbare, because it disappeared.
Some other suggestions:
- To modify a setting, just double-click on a setting, instead making a new setting and erase the previous.
- Also helpful would be, when there are several antennas at the list, to move them up or down on the list and stay there.
For me, the tuner reminder is very usefull , instead having a charts on the desk.
VY73, Hans DF2MC
Posted: 16 Jan 2016, 19:01
by KI0EO
I would agree with the "always on top".
I typically open it and put it in the open space under VFO A and VFO B.
Unfortunately, it goes to the bottom when I click anywhere in Log4OM.
As far as the title bar, as you can see, I rarely pay any attention to it.
Don...KI0EO...
Posted: 22 Jun 2017, 09:30
by VK7CW
I see this was discussed well over a year ago now, however nothing has changed.
I use the "Tuner Reminder" and would love to see it ALWAYS ON TOP, or at the very least an option to turn it on or off.
Could this please be looked at in an upcoming release?
73 Steve VK7CW
Posted: 22 Jun 2017, 09:56
by DF5WW
Hi Steve,
V1 is only in maintenance now so Lele is working hard on V2. Think that he will
change some things for the Tuner Reminder in V2 ...
