duplicate eqsl ????
Posted: 09 Feb 2016, 19:54
by SV9RGI
Good evening, I want to ask about the eqsl cards when push through some of my program sees yellow ie there double I want to know when a qso e.g. sv9rgi 24/10/2015 and sv9rgi 02/06/2015 while another year why not push the card does not have this capability; stand dates but sees the same call sign and considers double or wants a setting;
best 73 sv9rgi
Re: duplicate eqsl ????
Posted: 09 Feb 2016, 22:38
by K7PT
Maybe the date format. It now is DD/MM/YYYY, and not MM/DD/YYYY.
Posted: 10 Feb 2016, 06:45
by SV9RGI
Good morning and thanks for the reply to the first photo you see the message you sent me and in the second I search the call sign and see that there is only one contact with this call sign I can not figure out where the problem is;
Posted: 10 Feb 2016, 08:04
its showing a duplicate because you already have uploaded it to eqsl, or it is marked so
Posted: 10 Feb 2016, 08:26
by SV9RGI
Good morning and thanks for the reply but that contact does not exist in eqsl so there is no problem because obviously I had in this tab all YES played this role, but now that is changing it;
Posted: 10 Feb 2016, 15:40
These are the DEFAULT values set to every QSO when created.
If you set YES to the QSL SENT status, Log4OM will create all QSO logged with YES in the EQSL send status, so it ASSUME you have used something else to upload your QSO to the external services.
This screen is ONLY for DEFAULT values.
Setting values to NO will prevent (if not forced) upload. Default will be the correct values for QSO upload to EQSL system (EQSL SENT = R)
