I have been trying to figure out how to create custom filter in the cluster window (right hand side under the custom tab) here is what i am trying to do..
I want to create a rule that highlights all spots that are NOT within my privileges (i'm not an extra yet) I still want to see all of the spots but the color would be a good visual cue that the station is put of my band privileges.. I'm sure this can be done but I haven't been able to figure it out yet.. any suggestions would be much appreciated.
BTW, still loving the program.. I think i'm just about ready to uninstall HRD altogether.. Great forums and a great piece of software.
custom filter for cluster
Re: custom filter for cluster
KC0NTU wrote:I have been trying to figure out how to create custom filter in the cluster window (right hand side under the custom tab) here is what i am trying to do..
The custom highlights are operative on the comments and notes fields only - Not the band or mode
So for this reason it is not possible to do what you require
Try using cluster filter commands with the cluster server that you are using, you can exclude bands, modes and frequencies with those filters - Check out VE7CC and its CC user software
