Query for Empty Field
Posted: 03 Mar 2016, 12:12
by w0ls
I am trying to repair some entries in the log that do not include values for certain fields like Country, State etc. How do you do a search for empty fields? I have tried things like NULL, ' ' etc but no luck. Can anyone help me with this?
Thanks and 73's
Harry
W0LS
Re: Query for Empty Field
Posted: 03 Mar 2016, 12:35
Just select the required field and equal to but leave the box where you would normally type the data empty
This equates to:
State field equals empty
Posted: 03 Mar 2016, 13:59
by w0ls
That was easy..
I guess I was looking at it from a programmers perspective...you guys made it to easy!!
Thanks,
Harry
W0LS
Posted: 03 Mar 2016, 20:20
by HB9BRJ
An alternate approach, useful to get a visual overview about missing or incorrect values in general:
- in QSO Archive > Layout, make your field(s) visible
- set limit (bottom right) to 0 if there are more than 5000 QSOs in database
- click on Search to display all QSOs
- click on a column header to sort the list in ascending order
- click again on the same column header to sort the list in descending order
73, Markus HB9BRJ
Posted: 03 Mar 2016, 22:47
by w0ls
Thanks Markus...that works good as well. And I was not aware that you could change the limit...so that was good to know. I was actually trying to go a couple of levels....first country equal US and then state field empty...
Harry
W0LS
