Is there a way to filter the cluster display list not only by Band but by frequency range? For example, I do not hold an US Extra class license so seeing spots in the cluster list in parts of the band I can't operate is tantalizing, tempting and frustrating hi hi.
Mike
Filter cluster report by freq?
Re: Filter cluster report by freq?
Yes you can send commands to the cluster to filter out unwanted spots by frequency or anything you likeKA4CDN wrote:Is there a way to filter the cluster display list not only by Band but by frequency range? For example, I do not hold an US Extra class license so seeing spots in the cluster list in parts of the band I can't operate is tantalizing, tempting and frustrating hi hi.
Mike
See http://www.dxcluster.org/main/filtering_en.html
Fantastic. I've learned another new thing today and it isn't even noon hi hi.
Having said that --- I would be a nice feature to be able to define one's own band plans. I thought I saw that somewhere else in the program settings. If so, that could be used for the cluster reporting too maybe?
It looks like the cluster command only allows for defining one frequency range but I need to study on it some more.
Thank you.
Mike
Thank you.
Mike
Where can I edit my cluster logon script so I can add filters to it?
In the utilities/cluster window click the login script button just beneath and to the left of the connect buttonKA4CDN wrote:Where can I edit my cluster logon script so I can add filters to it?
