How do I reset DX Cluster "Worked" flag?
Posted: 14 Mar 2016, 12:16
by WA2SQQ
Hello Terry
I was recently trying to contact one of the DXpeditions, and thought I got through for the contact. I checked their log and discovered that I'm not in the log. I manually deleted the contact from the log. Yesterday the same DXpedition showed up on the DX Cluster and LOG4OM shows the station as "worked". How can I reset that country so it won't show up as being worked on the cluster? Shouldn't deleting the contact (assuming its the only one) also reset the "worked" flag?
In advance, thanks!
Re: How do I reset DX Cluster "Worked" flag?
Posted: 14 Mar 2016, 13:09
by K7PT
Deleting that contact should have done the trick. Possibly what your seeing is that you have them worked on a different band and that is what is showing.
If it is that station that is highlited, it is saying that your have worked them on "some" band. May not be the current one.
Posted: 14 Mar 2016, 13:55
by WA2SQQ
Nope, only entered them on one band, deleted it and when it popped up on the cluster it was showing that I worked them.
Posted: 14 Mar 2016, 14:11
WA2SQQ wrote:Nope, only entered them on one band, deleted it and when it popped up on the cluster it was showing that I worked them.
Did you restart Log4OM?
Posted: 14 Mar 2016, 17:30
by WA2SQQ
Yes - definitely.
I thought I worked the MARQUESAS ISLAND (TX7EU) expedition on their first day. Lots of QRM so I was not 100% certain. The contact was logged. Two days later I checked their on line log and I was not in it, so I manually deleted the contact. Yesterday they popped up on the DX Cluster again and the spot was highlighted as if I already worked the station (not just the country). Even if I had worked another station from that country, it should not have highlighted it as it does when I've previously worked the same station.
Posted: 14 Mar 2016, 17:34
Hello ????????
Check in the awards statistics to see if it shows worked for that country
Posted: 14 Mar 2016, 18:37
by WA2SQQ
Terry, I'll check this evening
Bob, WA2SQQ
