Cluster Colors
Posted: 21 Mar 2016, 22:37
by KG4GGG
This is probably an issue with the end user but I wanted to ask it anyway.
I go into Settings>Options>Cat and Cluster and I go to change the colors of the cluster highlights. Once I make my changes and save them, the changes do not show up in the cluster window on the main screen. The colors just stay at the default.
Am I doing something wrong or is this a known issue?
TIA
Roger
KG4GGG
Re: Cluster Colors
Posted: 21 Mar 2016, 23:41
by NN7D
Hi Roger,
First off, welcome to Log4OM and the forum!
On your cluster question, are you referring to the Cluster display on the main window F9 tab, or the separate cluster display which you can open by clicking on the far left tool button which looks like a green radar fan display? If the separate window, try closing out the window and reopening it again. If the F9 tab, try switching to another tab, then back. It works for me. Also, make sure you have SAVED your changes in the Log4OM Settings dialog before closing it out.
Also Roger, I will change your login to your callsign to be consistent and so others know where you are located, as it can make a difference with regions, rules, etc.
Hope this helps.
Doug - W7DRM
Re: Cluster Colors
Posted: 22 Mar 2016, 00:29
by KG4GGG
HI Doug,
I tried using my call and it said it was in use. I don't remember ever logging on to the forum until today since its the first time I had a question....
To answer your questions, I am sure I am saving as when I go back to the setting, my color changes are there.
My color changes seem to take in all cluster windows EXCEPT the one on the main screen on the right side. I don't know if these colors should change or they are not affected by the changes in the cluser settings.
Thanks again,
Roger
Re: Cluster Colors
Posted: 22 Mar 2016, 01:23
by NN7D
Roger,
The cluster colors settings for Worked/conf. (country/band/mode) and Country not worked/confirmed will affect the small cluster display in the lower right corner of the main screen. To refresh that display after you change the settings, just click on one of the spots. The other larger Cluster displays will update with the next spot, or by checking or removing the check in the Remove wrkd countries checkbox.
I hope this makes sense.
I will get you merged with your previous call or login.
Doug
