Super Cluster questions ?
Have noted that the F1 and F2 (function keys) do not "function" for the for the active Super Cluster window.
When I put the Super Cluster window in the background and make the main Log4OM window active the function keys all work just fine.
When clicking on a spot from the Super Cluster window it does populate the QSO data and does change the rig ... as this occurs the Super Cluster window goes to the background on my monitor.
Is there a way to keep the Super Cluster window in the foreground so I don't have to go searching for it to bring it back to view?
Re: Super Cluster questions ?
No you cannot make the super cluster remain in the foreground (On top) and if you could you would then have to "go searching for the logbook input window to bring it back to view"
Perhaps you could consider a larger or an extra monitor for your computer to provide more real estate for the windows you require to remain in view?
Terry,
Tnx much. I have a pretty large monitor (but keep it pretty full with larger font/size due to my "maturing" eyes ... :-( ) and also just put a spare monitor into use so have two available. I've been trying to get used to having the dual monitors and will move the Super Cluster over and "spread out" ... so to speak.
