FREQUENCY ERROR
FREQUENCY ERROR
Using ver 1.24, HB9HQX ver 3.2, the frequency that I was using is not what the log shows, using JT Alert 2.71, this just started abt a week ago, I am puzzled, seems ok with WSJT-X, running program as admin didn't help, Thanks for any ideas, Phil NS4T
- 0719cc21eb27448c8aa02bd611a91f42.zip
- (33.7 KiB) Downloaded 166 times
Re: FREQUENCY ERROR
Phil,
Are you saying that the frequency logged by JTAlert to Log4OM is wrong? If so, can you give an example of the value being logged and the value you expected to be logged.
de Laurie, VK3AMA
(JTAlert Author)
de Laurie, VK3AMA
(JTAlert Author)
Re: FREQUENCY ERROR
In the attached log file contact with LZ1UBO was logged as 14080.576, HB9HQX Logfile shows 14079.326
appx 5-25 @ 23:09
SP4TXI logged at 14079.871. logfile says 14077.351 5-25 @22:52
EA1IPN logged as 14079.254 Log file shows 14078.004 5-25 @ 22:40
Thanks for looking at this for me,, Phil
appx 5-25 @ 23:09
Re: FREQUENCY ERROR
Phil,
Since your looking at differences in what HB9HQX is logging and what Log4OM is recording, you should raise this issue with the HB9HQX author.
Your mention of JTAlert in your original post led me to think that JTAlert was doing the logging. Since it appears that HB9HQX is doing the logging, I can't help any further.
de Laurie, Vk3AMA
(VK3AMA Author)
de Laurie, Vk3AMA
(VK3AMA Author)
Re: FREQUENCY ERROR
Thanks for the reply, HB9HQX is set to log only to the default JT65 log, I do not have it checked to log directly to the LOG4OM setting in the program, I don't know exactly how it all works but my idea is JT Alert is doing the logging as I have that set up in the JT Alert setting tab,, Thanks Phil
