Locator (Grid Square) not found correctly v1.25
Posted: 21 Jun 2016, 19:01
by lu4hne
when I enter a new QSO always brings the locator the center of the country . Never recorded in the qrz.com .
I checked with my callsign
if i put LU4HNE gets FF74DL and I have loaded in qrz.com FF78UQ .
Besides this, the locator obtained not copy in the QSO info locator field , you have to enter it manually
Windows10
lo4om ver: 1.25
Spanish
cuando ingreso un nuevo QSO siempre trae el locator del centro del pais. Nunca del que tiene registrado en qrz.com.
Lo comprobé con mi licencia
Si cargo LU4HNE Obtiene FF74DL y yo tengo cargado en qrz.com FF78UQ.
Ademas de esto el locator obtenido no lo copia al campo locator del QSO info, hay que ingresarlo manualmente
Gracias
Re: Locator (Grid Square) not found correctly v1.25
Posted: 21 Jun 2016, 20:31
by K7PT
Are you a PAID subscriber to QRZ?
I see you are NOT a paid subscriber and that's the problem. You must subscribe to QRZ in order to receive the information you want.
Posted: 21 Jun 2016, 20:41
by lu4hne
im test ea6ddlog and this can obtain locator correctrly in same condition of suscription on qrz.
the paid subscriber is for
Custom Content No-Ads plus custom content options
XML Logbook Data High speed XML access for logbook programs
Database Downloads Download copies of the QRZ database to your desktop
Posted: 21 Jun 2016, 22:33
by K7PT
There are several levels of data from QRZ. You must be at least a XML subscriber as I am.
And, I believe, that ea6ddlog uses QRZCQ (a free service), not QRZ.
You may want to use HAMQTH instead of QRZ as it is free.
Posted: 22 Jun 2016, 00:33
by lu4hne
Thanks very much. I test this options
