MySQL Database
Posted: 01 Aug 2013, 10:24
Hi Guys,
I've been using Log4OM for a while now, and think it's a cracking program. However, I want to be able to use it for multiple machines and so I'm trying to set up a MySQL database.
I've got the database set up, and all machines connect correctly over the internet (it's on my VPS so I can access from my laptop anywhere). However, when I try to deploy the database, I get the following error...
String 'leighjep_m0nexUser' is too long
And then goes to mention a 16 char limit. The 'User' part isn't part of my username that i've entered and so it looks like a slight error in the coding.
This isn't a problem as such because it's only for the deploy database section - however, can anyone provide the SQL statements that the software actually provides to set up the database. That way I can set it up without having to wait for the next update to fix this.
Regards,
Leigh
Regards,
Leigh
