Icom 735 Slow speed on CAT changes
Posted: 23 Aug 2016, 07:35
Hello dear Friends and warm greetings to all from SV-land.
I am Apostolos SV1EDY and i have a small problem on cat speed when i work with my IC-735.
When i click to follow a spot on cluster the radio change and follow cluster but not immediately... Take his time , abt 7 sec.
This happened only in my 2nd qth and shack where i have the 735.
On my home base with my yaesu radios the changes are almost instant and radios follow the spot immediately .
The problem is with my IC-735 that is connected to a USB to SERIAL adapter
Settings are 9600,8,n,1 on OMNIRIG and the same on usb virtual serial port SERIAL port.
Icom 735 radio set to baud rate 9600 / 8 data bits / no parity / 1 stop bit DTR and/or RTS ON (set from jumpers inside radio).
Any idea why is so slow ?
My very best 73 to all
Apostolos
SV1EDY
Apostolos
SV1EDY
