Connecting to Log4OM with IC718
Posted: 08 Oct 2016, 20:23
Hi All,
I'm a new user to Log4OM and i'm having problems connecting my Icom 718 up to the software using the rig connection.
Having clicked the CAT button on the top toolbar I get the Log4OM CAT dialog box. I've selected the Icom 718 and the COM port automatically is populated with the correct one (I checked in Windows 10 device manager). The baud rate and stop bits were initially populated, but I had no luck in connecting to my rig. I have subsequently been altering these values manually to see if I have any luck. I have changed the baud rate to 1200 and stop bit to 1 and after hitting the 'Open' button for Hamlib, it connected successfully. However, as soon as I changed frequency the software stayed at the original frequency and came up with an error message 'Radio doesn't answer to calls. Retry'. So, I seem to be having partial success, but can't quite get to make the rig talk to log4om.
I've used the cable previously with other logging software and not had a problem.
Any ideas?
Cheers
Dave
M0IKT
Any ideas?
Cheers
Dave
M0IKT
