Station worked same band AND SAME MODE
Posted: 14 Oct 2016, 12:31
by dk2lo
When I worked recently in the AN400* competition I missed the feature to see straightforward if I had worked this station already on the same band and the same mode.
It would be nice to get another button in the Cat & Cluster settings (Cluster highlight colors section) to mark "STATION WORKED S. B. and SAME MODE". This would help very much in such competitions to avoid dupes. It is much harder to look through all the QSO details of a worked station to get the needed information.
Re: Station worked same band AND SAME MODE
Posted: 14 Oct 2016, 17:52
You can readily see in the cluster if the station was worked on the same mode, see my example below where I have worked GI0HWO on 40 meters phone but not CW - Phone is Green (Worked) CW is Red (Not worked)
Posted: 14 Oct 2016, 18:41
by dk2lo
I think this problem is more sophisticated. Your example does not refer to the station worked but to the country confirmed on this band/mode.
Here is an example:
station CO8LY worked on 12m CW
CO8LY on 12 m CW with mode in red
Cuba worked but not confirmed on 12m CW
I have worked CO8LY on 12 m CW but this contact and Cuba at all is still not confirmed on 12m. The last issue is the reason why the MODE shows up in red. If I would rely on this information I will make a dupe with CO8LY.
I need the information about the worked-status for the station and not the confirm-status for the country.
Posted: 14 Oct 2016, 21:31
Olaf,
What you are requiring is more related to contest working and needs to be an option in the contest tab but I do now more readily understand your thinking.
Perhaps in version 2 because version 1 is now on maintenance so no new features will be added to it.
Posted: 15 Oct 2016, 10:53
by dk2lo
thank you. It would be nice to see this feature in the new version 2.
This is not only an issue for competitions/contests. Also with DXpeditions or rare calls at all it would be an improvement to see at the first glance if this cluster spot is a new band and mode point for this call. This would avoid any embarrassing dupes.
