County
Posted: 12 Nov 2016, 18:18
by VE4DXR
Is there a quick way to populate the county award? I started manually entering but I have about 3000 to go.
73 Lee, ve4dxr
Re: County
Posted: 12 Nov 2016, 22:01
Yes you can bulk edit in the QSO Manager
First do a selection parameter sort as below
- Untitled.jpg (54.93 KiB) Viewed 2204 times
Then select groups of counties that don't have the QSO Award field completed and go to field update and edit the QSO Award field as required.
If the county names happen to be in the comments field then you can use the provided update for awards in the field update screen
