Additional Layout item for Recent QSO window
Posted: 17 Nov 2016, 08:48
by VK7XX
Today I was attempting to add another column of information to my Recent QSO window (version 1.26.0.0) and noticed that it does not exist... that is, QSO End ... 'QSO Start' is there, and 'QSO end date' is there, but not 'QSO End' (the qso end time as seen in the Update QSO info window when you go to edit a contact)
regards
John
VK7XX
Re: Additional Layout item for Recent QSO window
Posted: 17 Nov 2016, 09:32
VK7XX wrote:Today I was attempting to add another column of information to my Recent QSO window (version 1.26.0.0) and noticed that it does not exist... that is, QSO End ... 'QSO Start' is there, and 'QSO end date' is there, but not 'QSO End' (the qso end time as seen in the Update QSO info window when you go to edit a contact)
regards
John
VK7XX
I believe you are overlooking it in the list of fields, it could be down the bottom, because its working fine for me
- Capture.JPG (38.92 KiB) Viewed 5119 times
Posted: 17 Nov 2016, 20:07
by VK7XX
G4POP wrote:VK7XX wrote:Today I was attempting to add another column of information to my Recent QSO window (version 1.26.0.0) and noticed that it does not exist... that is, QSO End ... 'QSO Start' is there, and 'QSO end date' is there, but not 'QSO End' (the qso end time as seen in the Update QSO info window when you go to edit a contact)
regards
John
VK7XX
OMG how embarrassing.... you are right Terry, thanks. Yes, it was right down the bottom of the list out of alphabetical order. Next time I will look at the whole list.
regards
John
Posted: 17 Nov 2016, 21:39
Tasmanian Devils at work again, devious little swines
