Log4OM Portable
KB5WCK
Log4OM Portable
Post by KB5WCK »
I am using the portable version and suddenly it tells me access denied to several XML files in the Config folder. I have backed up my data , removed it, reinstalled the portable version and same thing. I have also removed the portable and installed the full version.... same thing. Any ideas on what could be wrong.
BTW, I am on Windows 7 x64 8gb RAM.
Re: Log4OM Portable
Norton antivirus?
KB5WCK
Re: Log4OM Portable
Post by KB5WCK »
Nope. Not sure what it could be. The exe launches but can't access several xml files in the Config folder. I went in and gave my username FULL rights to everything in the folder and still no go.
Re: Log4OM Portable
Sounds like you have some corrupr xml files, try archiving the xml files in another location and restore one of the Backup configuration files
Re: Log4OM Portable
Can you kindly check Log4OM log file from HELP menu?
It should show the reason of the error...
