I'm not sure what the process is to get awards added to Log4OM so posting this request.
Keith Roget Victorian National Parks Award (KRMNPA). This is an awards that hass been around since the 1970s and requires contacting activators in all 45 Victorian National Parks (VK3).
The award is on https://www.amateurradio.com.au/awards.
Also on the the same website is the Victorian Local Government Award for contacting the 79 local government areas of the Victorian Government. Both awards managed by Tony VK3XV
As not listed I created them as custom awards, XML Export files attached.
There is also a VK Shires Awards, similar to the Victorian Local Government Award but covering all shires of Australia. Details at http://www.vk4fw.com/vk-shires.php The award is managed by Bill VK4FW. This award has a related contest run every year and is also quite old.
The xml file for the VK Shires awards was too big to attach so attached in zip format.
73 Ian VK1DI
KRMNPA, Victorian Local Government and VK Shires Awards
Moderator: OE6CLD
- award_VK_SHIRES.zip
- (10.41 KiB) Downloaded 476 times
award_KRMNPA.xml
- (29.9 KiB) Downloaded 550 times
award_VLGA.xml
- (52.28 KiB) Downloaded 502 times
Re: KRMNPA, Victorian Local Government and VK Shires Awards
All awards has been uploaded to Log4OM website and will be distributed automatically to users at next award update (scheduled every some days or user selectable).
Thanks for sharing.
As suggestion: delete the 3 awards from your award database using the paper basket, they will be redownloaded with the "official" version
Thanks for sharing!!!!!
Thanks for sharing.
