I'm little bit in the confusion.
While logging Sat or EME QSO - "Propagation" is in the "Sat/Propagation" tab, antenna position in the "Extended info and QSL" tab.
While editing same QSO - "Propagation" , antenna position are in the "Country ..." tab.
May be possible to put Sats data, Propagation and Antenna position to same tab for logging and also while editing?
Thank you and HNY.
Sats, Propagation and Antenna position.
Re: Sats, Propagation and Antenna position.
As noted in your other thread V1.0 is in maintain mode only.
Ok, will wait ,second version of the log.
Thank you and Happy New Year to the Team and all Hams.
