New User Needs Help
n4et
New User Needs Help
Post by n4et »
I'm using Log4OM v 1.27.0.0 with WSJT-X v 1.7 and JTAlertX v2.9.0 My problem is that the Log4OM is logging duplicate QSO entries but with a different times. This started a day ago when I changed one of the settings. The duplicate entry shows up in the log after a JTAlert pop up notification says that the QSO was sent successfully to Log4OM.
Could someone direct me to the setting I must change back to stop the duplicate logging of QSOs.
Thanks in advance for your help.
Mark Wagner, N4ET
n4et
Re: New User Needs Help
Post by n4et »
Well I finally figured it out. I had both WSJT-X and JTAlertX both logging the QSOs. I turned off the JTAlertX logging and all is fine now.
Mark Wagner, N4ET
N6VH
Post by N6VH »
How do you have WSJT-X configured to log directly to Log4OM? I didn't know it was possible.
afwong wrote:Hi, I want to log every transmission that I made including unanswered CQ. How do I handle the callsign field for unanswered CQ call?
Enter CQ as the call sign?
