Cluster Stops Receiving Spots
WD1L
Post by WD1L »
Hello, I run a CC Cluster node, when I connect to it after a while I stop receiving spots, I do not get any sort of message that I am disconnected Log4OM just seems to go to sleep, I must push disconnect and then reconnect to start receiving spots again.
I have some users experiencing the same problem that are using Log4OM.
is there any sort of keep alive command that I am missing ??
Thanks for any Help.
John de WD1L
Re: Cluster Stops Receiving Spots
WD1L
Post by WD1L »
Thanks!! Terry
