Hello all
I tried an ADIF export Version 3x .
I expected an XML-file (.adx).
The export-process hangs ("ADIF export in progress").
Meanwhile a file in "traditional" adif format is produced.
<ADIF_VERS:5>3.0.4 <PROGRAMID:6>Log4OM <PROGRAMVERSION:8>1.27.0.0 <eoh>
Running on Win10Pro with all updates.
Did I something wrong ?
Marc on6ng
ADIF Export to .adx (xml) fails
Re: ADIF Export to .adx (xml) fails
Why did you expect an xml file it clearly states that it is an ADIF export?ON6NG wrote:I tried an ADIF export Version 3x .
Why do you say it hangs? are you sure that its not just finished?The export-process hangs ("ADIF export in progress").
