Any one come across the problem of display windows running into each other, or not big enough, or writing going out side of the window / box. The green ADD window just has AD .The CLR window has the top half of CLR.. I have uninstalled the program & reinstalled it.... but the config files stayed on disk with all my info.. maybe that's the problem.. not totally removing Log4om with all the config files.. & how do you do that if a uninstall doesn't .. Any one got any ideas. running the latest version.
Paul
VK2KTT
Windows running into each other or to small
Re: Windows running into each other or to small
Sounds like the recurring issue when a user sets the Windows screen display settings to something other than 100%
Nothing to do with Log4OM install or configurations
Thank you Terry,
That fixed the problem. Returned the display to normal.. All OK
Didn't think of that as all other programs running normal.
I must of changed the settings when I added a 2nd display
73's Paul
73's Paul
