Hi ALl
I have just noticed that in Smart SDR when I am in RTTY in log4om it logs it as SSB??
I haven't been that active over the last year so I cant remember if this is only a new issue or its always been like this,
I'm using Log4OM ver 1.24 and Smart SDR Ver 1.10.8
Trevor
EI2GLB
In Smart SDR RTTY is logged as SSB
Re: In Smart SDR RTTY is logged as SSB
Hi Trevor,
i am not a user of Smart SDR but it would be helpful if you update to the actual version of Log4OM first. We are on 1.27 now. You will find the actual version here: http://www.log4om.com/dl/
Also download and install the latest version of Omnirig and the Omnirig rig ini files
There have been many important changes between version 1.24 and the latest version of Log4om, it might be useful to suspect the SDR software also?
Thanks for the replies, I have updated to the latest Log4OM and Omnirig and the issue is still there,
I will post on the Flex user community as well,
Trevor
EI2GLB
Trevor
EI2GLB
Hi Trevor,
If you read through this thread it will give you some background on why this is occurring. Hopefully, there will be a fix in V2 of Log4OM.
viewtopic.php?f=6&t=2652
Doug - W7DRM
Doug - W7DRM
