Other info column
Posted: 13 Mar 2017, 22:48
by WB4M
I've noticed that the "Other Info" column in the cluster retains previous comments. For instance, I spot the E51. In the Other Info, this shows up:
RTTY simplex....lonely
RTTY simplex....strong
FB Instant OQRS Clublog!
RTTY
RTTY Simplex, 599 in MI
RTTY via QRZ.Com/E51DWC
Simplex with dipole /100watts
RTTU simplex Long Path
RTTY simplex no waiting
CQ CQ Simplex
rtty simplex
RTTY not busy!!
RTTY simplex
RTTY simplex
Simplex
Needless to say I didn't type any of this in my spot. Is there a way to not have previous comments included in what I spot? Sometimes it's name calling and I don't want others to think I made those type of comments. I guess I could just close that column and not look at it but it's still there.
Re: Other info column
Posted: 14 Mar 2017, 07:23
I don't understand what or where this 'Other Info' column that you refer to is - Please explain fully where you see this column?
Are you sure it is in our software?
Posted: 14 Mar 2017, 13:05
Hi, this is not what you're spotting. Those informations are grouped from multiple received spots on the same callsign/mode/band
Log4OM cluster groups reports to avoid duplicates, but retains the latest 15 spot informations in that field.
Posted: 14 Mar 2017, 13:13
by DF5WW
this is the column that WB4N (Name in a signature please) refers to:
As Lele said, that´s only comments of the latest spots for this callsign it is not what WB4N send to the cluster. In a normal cluster in the web nobody see this information as part of a WB4N spot.
Posted: 14 Mar 2017, 13:48
DF5WW wrote:Hi Terry,
But that is INCOMING spot information and it is not re sent when the user of Log4OM spots a DX Call ??????????????????????
