Multiple Band Selection in Cluster Window
Posted: 15 Mar 2017, 12:33
by KD0Q
Please consider the following feature.
An ability to select multiple bands for including spots in the Cluster window. For example, in the early morning before sunrise I want to see spots for 160, 80 and 40 meters but not the rest of the bands. After sunrise I want to see the higher bands but not 160 and 80 meters.
Thanks and 73, Glenn - KD0Q
Re: Multiple Band Selection in Cluster Window
Posted: 15 Mar 2017, 16:49
You can already do that by sending a band filter to your cluster provider from the cluster command line in Log4OM
See http://wiki.dxcluster.org/index.php/DXS ... ing_Manual
1. In Log4OM go to Utilities/cluster
2. Enter the filter in the 'Send Command' field as shown below
3. Then click on 'Send Command'
Posted: 17 Apr 2017, 12:30
by KD0Q
If you are connecting to VE7CC Cluster, band mode filter settings are different, explained at http://www.bcdxc.org/ve7cc/ccc/cccdxbm.htm.
In either case, I think filter settings have to be followed with sh/mydx command or something to refresh the Cluster tab.
I was hoping for something more along the lines of replacing the dropdown band list with a set of checkboxes so that the change could be done in place.
73, Glenn KD0Q
