Misalignment when printing labels from PDF
Posted: 27 Mar 2017, 10:20
by SV1EDY
Hello dear friends
I have the following problem.
I creat the PDF with my labels from log4om but when i start to print the labels while going down the printing on page are misaligned vertically .
The first row is ok , the 2nd is little more down the third even more etc etc . After 5 rows the labels are start two printed half on one label and half on the next...
Any ideas please ???
Best 73
Apostolos
SV1EDY
Re: Misalignment when printing labels from PDF
Posted: 27 Mar 2017, 14:23
So little information!
What label stationary are you using?
What printer?
What Log4om label template have you selected?
Posted: 27 Mar 2017, 16:52
by CT1BXX
Hi Apostolos,
I have had a similar situation. After checking, the problem were the measures I was using in a new label I was creating. If you permit firstly try to print using a common label to see if it works fine, if not, please check the measures you are using (in case you are creating a new label)
Posted: 28 Mar 2017, 08:00
by SV1EDY
Hello der Friends
Sorry for little information.
I use laser printer LaserJet HP1022 -
Labels are in A4 sheet - Each sheet have 3 columns with 8 labels per column. Total 24 labels .
Each label is 70mm width and 37mm height.
The labels are the one next to the other without any gap , like a sheet of A4 paper that someone use a scalpel to separate the labels.
The 3-4 for rows from top are ok but like something happened and each label goes little more down so at row 6-7 etc the pse qsl goes to the next label and the next label more down etc...
I create my own label , the same problem , for some reason the first labels on the first rows are ok but progressively comes the disaster...
Any ideas my friends ???
P.S. I check printer setup , all are in A4 normal settings .
I go now for further tests,. if any idea pse help me in your spare time .
Again best 73
Apostolos
SV1EDY
Posted: 28 Mar 2017, 08:46
Did you try using the 'Corrective factor' as shown below - Change the vertical correction
Screenshot 2017-03-28 09.39.21.jpg (61.26 KiB) Viewed 5327 times
Posted: 28 Mar 2017, 08:50
by SV1EDY
Terry tnx for fast reply, i see that but i dont know what to put there , how to measure and what to measure...
Apostolos
SV1EDY
P.S. What is also the propotional ???
Posted: 28 Mar 2017, 09:17
Just try adding values and watch result on print
I always test on plain paper and then compare to labels by holding up to the light
Posted: 28 Mar 2017, 15:10
by SV1EDY
Terry Fixed !!! I use vertical corrective factor 1 and now labels printed all ok !!!
Many thanks my friend and many thanks also to all friends who post a reply and help me
Best 73
Apostolos
SV1EDY
Posted: 28 Mar 2017, 16:36
Another satisfied customer :D
