Worked pop up
Posted: 30 Mar 2017, 13:02
by g4lds
Hi
Just reloaded LOG4om latest issue (Thanks Guys) cos lappy died
Just noticed when entering new qso I dont get "Worked" pop up screen or qso details auto entered
Have these options now longer used or is it (as usual) finger or an option not checked?
Cheers
Chris
G4LDS
Re: Worked pop up
Posted: 30 Mar 2017, 16:00
Did you check the options to ensure that lookup of old QSO's is enabled
Re: Worked pop up
Posted: 01 Apr 2017, 10:32
by g4lds
thanks Terry
No but just checked and it is
i thought as i use qrz.com that the new qso info like name was downloaded from qrz into new qso data or was i dreaming that??
Re: Worked pop up
Posted: 01 Apr 2017, 17:01
Chris,
The lookup from an old QSO indicating 'Worked' is functioning fine for me so either the boxes indicated below are not checked or you have a bad download or installation.
- Capture.JPG (83.89 KiB) Viewed 4278 times
- Untitled.jpg (84.42 KiB) Viewed 4278 times
With regard to the QRZ lookup you should get the name returned from the lookup but if you want full QRZ lookup you have to pay for an XML subscription which I notice that you have not done because QRZ shows you as just a 'Ham member'
If you want a free lookup service I suggest you try HamQTH
Re: Worked pop up
Posted: 03 Apr 2017, 13:19
by g4lds
Thanks Terry for that
Hope BoC still sunny
I have the boxes highlighted & the "worked/Worked Same Band" comes up now!!
I have on older qsos under the QSO information page the Name, address & qth I am sure that this was automatically filled in but recent (from latest ungrade date ) qso the same Station I reworked these fields dont appear to fill auto
Looks like a back up of data then reload programe!!
Re: Worked pop up
Posted: 03 Apr 2017, 13:26
Chris,
No the address details have not been auto filled from old QSO's for years because like me the OM may operate from many different locations, its just the name that autofill's
Re: Worked pop up
Posted: 04 Apr 2017, 21:53
by g4lds
thanks terry
answered that!!!
