CW-R problems
TA2SE2
CW-R problems
Post by TA2SE2 »
I need a help, please help me. My device is a 7410. I made a Cat control setup. But, the software is CW-R. I need my CW. How can I fix?
Thank you.
73-88
Rıfat Tultak
TA2SE
Re: CW-R problems
What are you using for CAT ?? Hamlib or Omnirig ??
TA2SE2
Re: CW-R problems
Post by TA2SE2 »
Hi Juergen
I use Omnirig
Re: CW-R problems
Hi Rifat (hope it´s the personal name and not the family name, HI),
i have checked the rigs in Omnirig and there are two IC-7410 included. File IC-7410 is dated from 2011 and IC-7410v2 ist dated 2015. Have you tried the newer rig file too ? If not try this first and talk bach if it not works.
Have a nice rest of the sunday ... Juergen, DF5WW
TA2SE2
Re: CW-R problems
Post by TA2SE2 »
Om Juergen. Rifat is my first name.
I tried the IC-7410v2. The result is negativ.
Re: CW-R problems
O.k. next step.
Make a save copy of the original IC-7410 rigfile and store it on another place of your HDD. Then delete the original one rigfile.
Download the attached rigfile unpack it and place it in the Omnirig Rig directory. Check out it works or not and tell us.
IC-7410.rar
(911 Bytes) Downloaded 594 times
TA2SE2
Re: CW-R problems
Post by TA2SE2 »
The file does not open. Please mail me. rifattultak2 % gmail.com
Re: CW-R problems
Hi Rifat,
send you a Mail with the unpacked rig file .... ;)
Copy it in the Omnirig Rig folder but before store the original one.
Juergen, DF5WW
TA2SE2
Re: CW-R problems
Post by TA2SE2 »
OM Juergen,
I'm happy. :D :D :D The file worked.
Thank you so much.
Good DX. Cu agn. GE
Rıfat Tultak
TA2SE
Re: CW-R problems
Hi Rifat,
nice that it works. The steps are very simple. I opened the original rigfile with Notepad++ (i use this so it don´t change the structure of a file). When i have it open i take a look for CW and CW-R but i have seen only CW_U and CW_L. In both i changed the numbers. B.t.w for CW_U i´ve found a "16.03" and for CW_L a "16.07" .. i changed now CW_U to ".07" and CW_L to ".03" ... that´s all.
Hope you enjoy Log4OM and the "Service" ;) ;)
