Yaesu FT 1200 and CAT
Posted: 01 May 2017, 16:13
by W1XOO
Just wondering if there is a way to connect the CAT to my FT 1200? I have not found the radio listed in the menu choices, or is there another radio that is used from the menu. Thank you very much for your help.
Re: Yaesu FT 1200 and CAT
Posted: 01 May 2017, 18:56
Install Omnirig and that should work
Posted: 01 May 2017, 23:17
by W1XOO
Very good I will check I thought I did install, but I could have missed it. Thank you for the help.
Posted: 02 May 2017, 03:45
by W1XOO
I must be doing something wrong as I did re-install OmniRig but no control to the radio. I will just have to poke around a while. Thanks for the help.
Posted: 02 May 2017, 06:54
Try the FT450, FT2000, 3000 or 5000 Omnirig selections or alternatively use the Hamlib FT1200 download from here http://hamlib.sourceforge.net/sup-info/rigmatrix.html and change to Hamlib as a last resort
Posted: 02 May 2017, 19:00
by W1XOO
Thank you for all the help. All is good, and working fine. I deleted and re-installed plus played with the baud rate. As for the FT 1200 it works on the FT 450 profile.
