60m shows out of band
Posted: 03 May 2017, 03:30
by k2oo
How do I configure (or change a configuration file) so that 60m doesn't show out of band. I will only be operating CW -- if that makes any difference.
Andy, k2oo
Re: 60m shows out of band
Posted: 03 May 2017, 06:51
k2oo wrote: 03 May 2017, 03:30 How do I configure (or change a configuration file) so that 60m doesn't show out of band. I will only be operating CW -- if that makes any difference.
Andy, k2oo
Locate the bandplan_r2.xml file which usually resides in the C:\Users\YOUR USER NAME\AppData\Roaming\LogOM folder
Edit the required frequencies in the file using Notepad and when finished save it to the same folder with the name bandplan_r2_user.xml
Restart Log4OM
I am surprised that the supplied bandplan_dxcc291.xml is not correct! this is the band plan that Log4OM would default to if your entered your country and DXCC correctly in the options/station info tab.
