Page 1 of 2
Don´t have awards
Posted: 25 May 2017, 17:36
by EC1AIJ
I can´t see any award
Re: Don´t have awards
Posted: 25 May 2017, 19:56
by K7PT
Have you downloaded the awards database from Settings>Awards Database? Try that.
Posted: 26 May 2017, 08:22
Did you click the drop down to see if the list is there, nothing will show until you do because there are many awards applicable to a call sign
- Untitled.jpg (63.54 KiB) Viewed 9781 times
Posted: 26 May 2017, 09:38
by K7PT
I assumed he had looked at the drop-down and it was empty. I know what "assumed" spells!!!! HiHi
Posted: 26 May 2017, 13:27
He may have assumed that it was empty or that it should auto populate but which award should we populate it with ?
Posted: 27 May 2017, 05:22
by EC1AIJ
It´s empty for all callsigns and I download the last updates.
The program always work correctly. I assume that has been due to problems arising from the last windows update
Posted: 27 May 2017, 06:16
EC1AIJ wrote: 27 May 2017, 05:22
In C:\Users\YOUR USER NAME\AppData\Roaming\LogOM do you have a file called 'awards_user.xml' or similar?
If not then email me and I will send you an awards file to import
Posted: 27 May 2017, 07:57
by EC1AIJ
Posted: 27 May 2017, 08:46
Do you have Teamviewer?
Posted: 27 May 2017, 09:56
Do not post Team viewer user names and passwords on this forum - Direct EMAIL to the recipient only to preserve your security
