No Frequency Info On Log
KG5THA
Post by KG5THA »
Good day, a quick question on log information. I have a Kenwood TS-590SG fully integrated with Log4OM through omnirig, all functionality working as intended except that no frequency information gets created on the log. I have read through the manual, and watched most of the setup videos on YouTube and believe I have installed and configured the program correctly. Any help would be appreciated.
NN7D
Re: No Frequency Info On Log
Post by NN7D »
Hi Krusher?
You say you have full functionality. You can change frequency by double clicking on a spot in the Log4OM cluster display and the radio will switch to the frequency? Are you getting the frequency readout in the upper right corner of the main Log4OM window - like in this image?
By the way, it is customary to use your ham call sign as your user name in this forum. That way, we have an idea of where you live so that we can provide better support - as there are differences in how the program operates depending on the country, zone, band plan, etc.
Doug - W7DRM
KG5THA
Post by KG5THA »
Thank you for the quick reply. Sorry for not using my call sign for my user name. Call sign is KG5THA. Yes I have full functionality, can change frequency by clicking on cluster, and frequency shown I upper right corner as indicated. The frequency of contact will show if I click on a contact in the recent QSO tab, along with their full profile. Just don't have a frequency on the main recent QSO tab, not even a space/placeholder for it, if that makes sense.
Click the layout button at the bottom and add the frequency to the recent QSO grid
I have changed your user name to your call sign in line with this forums requirements and our other users, your password has not been changed
KG5THA
Post by KG5THA »
Thanks Terry that did it. Must have missed it in the manual.
