Log4OM with N4PY Pegasus plus
Posted: 31 May 2017, 17:15
by KE4YH
Is anyone using Log4OM with Pegasus plus? I tried following the instruction in the Pegasus Manual but it isn't specific enough.
I have set up virtual com ports for this but that's as far as I can get. Any help will be greatly appreciated.
Stew ke4yh
Dunedin, FL
Re: Log4OM with N4PY Pegasus plus
Posted: 01 Jun 2017, 19:50
by LB2EG
Stew,
Have you used a virtual com port emulator software, defined av port-pair, and configured N4PY software to trick Log4om Omnirig/hamlib to connect to N4PY software as a kenwood transceiver?
It works ok when correctly configured
Richard LB2EG
Posted: 02 Jun 2017, 20:14
by KE4YH
I have the ports set up but that's as far as I got. Tried before and somehow lost all my QSOs from the database.
Guess I need to do more research.
Stew ke4yh
Posted: 03 Jun 2017, 00:38
by KE4YH
OK, I have it working now.
Stew ke4yh
