Awards / DXCC status
Posted: 01 Jul 2017, 07:45
by ON7CL
Hello FM,
When I want to look for my DXCC status the 4m band is not showing, it's showing in the grids and in my settings it's checked.
How can I see my DXCC status on 4m ?
Thanks for reply.
Rudi / ON7CL
Re: Awards / DXCC status
Posted: 01 Jul 2017, 20:38
by PE5TT
I had the same problem and edited awards.xml , now i can select the 4M band in the DXCC award status.
But LOG4OM is acting strange. i tried to add the 4meter band to all award sections in the "awards.xml" file , but then things got broken and i was not able to select anything. Strange is also the 70cm band is not declared anywhere in the "award.xml" file , however it is showing up in the DXCC MIXED status and other MIXED awards, but i was not able to get the 4 meter band show up there.
What i did is only add the 4meter award definition to "awards.xml" at the top of the file, starting at line number 183 i added:
Code: Select all
<Award>
<AwardCode>DXCC_4M</AwardCode>
<Band>4m</Band>
<AwardSearchParameters>
<QueryParameter>
<ParamOperator>=</ParamOperator>
<ParamValue>4m</ParamValue>
<ParamName>BandParam</ParamName>
<TableColumn>band</TableColumn>
<Query />
</QueryParameter>
</AwardSearchParameters>
<AwardSponsor>ARRL</AwardSponsor>
<AwardName>DXCC 4m</AwardName>
<AutonomousAward>false</AutonomousAward>
<AdifValue>DXCC_BAND</AdifValue>
<AwardAlias>DXCC-4</AwardAlias>
</Award>
That is between 6 meter en 2 meter award section, and now i can select the 4 meter band from the DXCC status dropdown menu.
If you try this , please make a copy of your "awards.xml" file first, so you can always go back to the original version.
Posted: 01 Jul 2017, 22:08
ON7CL wrote: 01 Jul 2017, 07:45
Hello FM,
Thanks for reply.
Rudi / ON7CL
You just found a bug and it must have been like this for ages!
I will get Lele to fix it for the next maintenance release
Posted: 10 Apr 2018, 20:06
by sp8sn
Hallo. I have the same problem with 60m band.
How can I add it to this list below ?
Robert SP8SN
Posted: 10 Apr 2018, 21:32
I don't believe that Dxcc incĺudes 60m, perhaps Chuck can advise?
Posted: 21 Aug 2018, 13:06
by N5ZY
Correct, 60m is not valid for DXCC.
http://www.arrl.org/dxcc-rules
Posted: 21 Aug 2018, 20:13
by K7PT
60M is not for DXCC
