Windows 10, USB Port and Omnirig
Posted: 07 Jul 2017, 01:33
by k1fj
I had been running a Windows 10 laptop with Log4OM and Omnirig with an FT-1000d with out any issues.
Recently I changed my laptop from a Dell to a Lenovo , still running Windows 10, but now I cannot get the Omnirig to talk to the FT-1000d. I suspect that Windows 10 on the Lenovo has the serial port in some kind of secure mode that restricts the use of the serial port, maybe due to the Omnirig not being a trusted source? I looked at the event logs for the USB serial port and there was a comment in the log about the port being restricted but that it could be unlocked. Any clue as to what Windows 10 page I can navigate to to remove the restriction? I am not sure why this is a problem now versus the other laptop, maybe this is a slightly different Windows 10 load and some default security feature?
73 , Frank K1FJ
Re: Windows 10, USB Port and Omnirig
Posted: 07 Jul 2017, 06:10
Make sure that you are running both Omnirig and also Log4OM 'As an administrator'
Posted: 10 Jul 2017, 11:39
by k1fj
I did set both LOG4OM and Omnirig to be run as administrator, but I still get no CAT frequency boxes at the top right, and the CAT status is still red.
I am using a RS-232 to USB convertor, then to a Yaesu interface box to get to the CAT data from the FT-1000D. That has worked for years, but in the off chance, I did reload the drivers for the RS-232 to USB interface and they seem to be functioning, according to the device manager.
I am just confused as to why this is not working, everything seems to be in order, but obviously it isn't.
Frank K1FJ
Posted: 14 Jul 2017, 01:17
by k1fj
To close this issue out:
I found that the problem I was having was two fold.
1) I had to use the Windows 10 default drivers for the RS-232 to USB convertor and not the stock ones supplied by the manufacturer;
2) Omnirig had to be set to "2" stop bits versus "1" for the Yaesu FT-1000D.
Once this was done, the system was functioning again.
Frank/K1FJ
Posted: 14 Jul 2017, 01:51
by 9y4C
k1fj wrote: 10 Jul 2017, 11:39
I am having a similar problem but unlike K1FJ my cat indicator is green, i can key the rig with the PTT button but No cat frequency shows up to the right and No frequency and band change when I select an item from the cluster, BTW my rig is a FT 950 and I have full functionality when using Ham Radio Deluxe and other programs is there something I need to activate in the radio menu. please help, i really like this software.
Posted: 14 Jul 2017, 07:20
9y4C wrote: 14 Jul 2017, 01:51
Usual questions!
1. Are you using the latest version of Omnirig?
2. Did you install Log4OM and Omnirig with administrator privileges?
3. What interface are you using between the computer and the radio?
4. What other software is running at the same time as Log4OM?
5. Did you try re-installing Log4OM in case you had a bad download and install before?
6. Have you tried disabling any anti-virus, malware and firewall software?
Posted: 15 Jul 2017, 21:45
by 9y4C
Yes I am using the Latest Version of omnirig
Yes i installed both with an Admin account
Serial to USB
I run only Log4om since I have been Trying, No other software Using the com port
Uninstalled and re-installed several times
Yes
Posted: 16 Jul 2017, 06:30
9y4C wrote: 15 Jul 2017, 21:45
Serial to USB
Yes
Please send me a support request as detailed here
http://www.log4om.com/log4om-support/
My email is g4pop (AT) arrl.net
Posted: 21 Jul 2017, 06:00
Fixed
The user had altered the default Omnirig settings for his rig, presumably because the program he used to use employed something different!
Once the normal default settings for his radio were selected everything worked fine.
